Gast Geschrieben 31. März 2021 Share #1 Geschrieben 31. März 2021 Werbung (verschwindet nach Registrierung) Wie schon vor einiger Zeit von Panasonic angekündigt wurde, geht es Schritt für Schritt los mit den Firmwareupdates Die anderen Modelle folgen kurze Zeit später mit spezifischen Updates So funktioniert das Update Lumix DC-SH1 FW Version 2.4 März 31, 2021 RAW video data output over HDMI to Blackmagic Video Assist 12G HDR - [5.9K] / [4K] / [Anamorphic (4:3) 3.5K] 12-bit RAW video data can be output over HDMI to Blackmagic Video Assist 12G HDR, to be recorded as Blackmagic RAW. * All functions may not be available depending on the situation. * DaVinci Resolve or DaVinci Resolve Studio is required to play back the Blackmagic RAW data. DaVinci Resolve Studio is required to edit the Blackmagic RAW data. Added functions - Users can choose to add or not to add camera orientation information in [Vertical Position Info (Video)] menu to prevent unintended image rotation in playback. - [Power Save Mode] can be selectable while the camera is powered with an AC adaptor(DMW-AC10, sold separately). Other added functions - There were rare cases that the display such as AF frame blinks during video recording. This phenomenon has been solved. - There were rare cases that operating the camera during photo/video playback of play back of photos and video caused a freeze depending on the operation timing. This phenomenon has been solved. - There were cases that the specified AF position was shifted when using Pinpoint AF in full screen display. This phenomenon has been solved. - There were cases video files were not recognized properly when they were saved in the specific SD card that is not fully compliant with the required commands. This phenomenon has been improved. Operating Instructions for the Change of Specifications Link zum Beitrag Auf anderen Seiten teilen More sharing options...
Werbung Geschrieben 31. März 2021 Geschrieben 31. März 2021 Hi Gast, Das könnte für dich interessant sein: Panasonic Lumix S Modelle Firmware Updates . Da findet jeder was…
Gast Geschrieben 6. April 2021 Share #2 Geschrieben 6. April 2021 Lumix DC-S1R FW Version 1.8 April 6, 2021 Added functions - Users can choose to add or not to add camera orientation information in [Vertical Position Info (Video)] menu to prevent unintended image rotation in playback. - [Power Save Mode] can be selectable while the camera is powered with an AC adaptor(DMW-AC10, sold separately). Other improvements - There were rare cases that the display such as AF frame blinks during video recording. This phenomenon has been solved. - There were rare cases that operating the camera during photo/video playback caused a freeze depending on the operation timing. This phenomenon has been solved. - There were cases that the specified AF position was shifted when using Pinpoint AF in full screen display. This phenomenon has been solved. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
Gast Geschrieben 6. April 2021 Share #3 Geschrieben 6. April 2021 Lumix DC-S1 FW Version 2.0 April 6, 2021 New functions and options to be available with the Upgrade Software Key DMW-SFU2. *Users who already have DMW-SFU2 do not need to purchase extra DMW-SFU2. There is no need of upgrading the camera with DMW-SFU2 if upgrading with DMW-SFU2 was once done before. - The following functions and options will be available by activating the [Activate] menu in the camera. » 6K(5952x3968) / 5.9K(5888x3312) / 5.4K(5376x3584) video recording mode in MOV format - 6K24p, 4:2:0 10bit LongGOP, 200Mbps, LPCM - 5.9K30p/25p/24p, 4:2:0 10bit LongGOP, 200Mbps, LPCM - 5.4K30p/25p, 4:2:0 10bit LongGOP, 200Mbps, LPCM » C4K(4096x2160) video recording mode in MOV format - C4K60p/50p, 4:2:0 10bit LongGOP, 200Mbps, LPCM - C4K60p/50p, 4:2:0 8bit LongGOP, 150Mbps, LPCM - C4K30p/25p/24p, 4:2:2 10bit LongGOP, 150Mbps, LPCM » 4K(3840x2160) 10 bit video recording mode in MOV format - 4K60p/50p, 4:2:0 10bit LongGOP, 200Mbps, LPCM » Anamorphic(3328x2496) video recording mode in MOV format - 4K-A50p, 4:2:0 10bit LongGOP, 200Mbps, LPCM - 4K-A50p, 4:2:0 8bit LongGOP, 150Mbps, LPCM - 4K-A30p/25p/24p, 4:2:2 10bit LongGOP, 150Mbps, LPCM » RAW video data output over HDMI - [5.9K] / [4K] / [Anamorphic(4:3) 3.5K] 12-bit RAW video data output over HDMI. - The Apple PreRes RAW can be recorded on Atomos NINJA V. *All functions may not be available depending on the situation. *Software that supports Apple ProRes RAW is required to edit RAW video recorded with NINJA V. *Apply the LUT(Look up table) available on the following customer supports site to make the same color grading as V-Log/V-Gamuthttps://panasonic.jp/support/global/cs/dsc/download/lut/s1h_raw_lut/ » [Time Code] function Other added functions - [Dual Native ISO Setting] function has been added. - Users can choose to add or not to add camera orientation information in [Vertical Position Info (Video)] menu to prevent unintended image rotation in playback. - [Power Save Mode] can be selectable while the camera is powered with an AC adaptor(DMW-AC10, sold separately). Other improvements - There were rare cases that the display such as AF frame blinks during video recording. This phenomenon has been solved. - There were rare cases that operating the camera during photo/video playback caused a freeze depending on the operation timing. This phenomenon has been solved. - There were cases that the specified AF position was shifted when using Pinpoint AF in full screen display. This phenomenon has been solved. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
Gast Geschrieben 6. April 2021 Share #4 Geschrieben 6. April 2021 Lumix DC-S5 FW Version 2.2 April 6, 2021 Added functions - Users can choose to add or not to add camera orientation information in [Vertical Position Info (Video)] menu to prevent unintended image rotation in playback. - [Power Save Mode] can be selectable while the camera is powered with an AC adaptor(DMW-AC10, sold separately). Other improvements - There were rare cases that the display such as AF frame blinks during video recording. This phenomenon has been solved. - There were rare cases that operating the camera during photo/video playback caused a freeze depending on the operation timing. This phenomenon has been solved. - There were cases that the specified AF position was shifted when using Pinpoint AF in full screen display. This phenomenon has been solved. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
pero Geschrieben 6. April 2021 Share #5 Geschrieben 6. April 2021 Ich habe die Firmwareversion 2.0 auf der S1 eingespielt. Verlief wie üblich problemlos. Und jetzt ist auch ein neuer Menüeintrag für Dual-Native ISO zu finden. Entweder AN, AUS oder Automatik anwählbar. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
hartin Geschrieben 6. April 2021 Share #6 Geschrieben 6. April 2021 Moin, sonst noch irgend Jemand was bemerkt an der neuen Firmware,also das z.B. der AF "flotter" ist ? Beste Grüße Link zum Beitrag Auf anderen Seiten teilen More sharing options...
Tom_Ra Geschrieben 6. April 2021 Share #7 Geschrieben 6. April 2021 Werbung (verschwindet nach Registrierung) Bei der S1R nicht, aber das Update ist verglichen zu den anderen Kameras ein Witz. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
hartin Geschrieben 6. April 2021 Share #8 Geschrieben 6. April 2021 Ja ,geb Dir Recht,ich merke nix was besser ist ,als vorher ,außer im Videobereich,da ich ja fast nur Fotografiere,hat sich das neue Update für mich nicht so gelohnt? Nun muß ich wieder meine alten Einstellungen konfigurieren...😐 Link zum Beitrag Auf anderen Seiten teilen More sharing options...
Gast Geschrieben 7. April 2021 Share #9 Geschrieben 7. April 2021 LUMIX S Series Camera Major Feature Comparison after updating the camera with the latest firmware after April 6, 2021 Hallo, lieber Besucher! Als Forumsmitglied (kostet nix) würdest du hier ein Bild sehen… Einfach hier registrieren – Wir freuen uns immer über neue Mitglieder! Link zum Beitrag Auf anderen Seiten teilen More sharing options...
hartin Geschrieben 7. April 2021 Share #10 Geschrieben 7. April 2021 Ich habe auch das "V-LOG" installiert,bemerke aber wenig von dem Update? Link zum Beitrag Auf anderen Seiten teilen More sharing options...
pero Geschrieben 7. April 2021 Share #11 Geschrieben 7. April 2021 vor 16 Stunden schrieb hartin: Ja ,geb Dir Recht,ich merke nix was besser ist ,als vorher ,außer im Videobereich,da ich ja fast nur Fotografiere,hat sich das neue Update für mich nicht so gelohnt? Nun muß ich wieder meine alten Einstellungen konfigurieren...😐 Echt? Bei mir ging nix durcheinander. Ich musste hinterher nichts neu konfigurieren. Das ist aber mal seltsam. Mir ist nur beim rumspielen mit dem neuen jetzt explizit anwählbaren Dual-ISO Eintrag aufgefallen, das der der High ISO Bereich schon bei 640 losgeht. Das erscheint mir ein bisschen niedrig. Ich hätte irgendwas bei 1600 aufwärts erwartet. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
frank.ho Geschrieben 7. April 2021 Share #12 Geschrieben 7. April 2021 Hallo weiss oder ist jemand eine Infoquelle dafür, wie ich an der S1 nun die Schaltmöglichkeit von LOW / HIGH bei Dual Native ISO sinnvoll nutze ? Einfach gesagt - was mach ich damit ? Meines Wissens ist der Dual-Sprung bei 800 ISO, die dann wieder besser sind wie zB 400. OK - und was mach ich da wenn ich auf HIGH schalte ? Oder LOW ? Etwas mehr Doku wäre sicher nicht schlecht Pana. Und hat jemand eine Link zu den Manuals direkt bei Pana ? Ich könnte ja mal in dem der S5 schauen... Grüsse Frank Link zum Beitrag Auf anderen Seiten teilen More sharing options...
pero Geschrieben 7. April 2021 Share #13 Geschrieben 7. April 2021 vor 4 Minuten schrieb frank.ho: Hallo weiss oder ist jemand eine Infoquelle dafür, wie ich an der S1 nun die Schaltmöglichkeit von LOW / HIGH bei Dual Native ISO sinnvoll nutze ? Einfach gesagt - was mach ich damit ? Meines Wissens ist der Dual-Sprung bei 800 ISO, die dann wieder besser sind wie zB 400. OK - und was mach ich da wenn ich auf HIGH schalte ? Oder LOW ? Etwas mehr Doku wäre sicher nicht schlecht Pana. Und hat jemand eine Link zu den Manuals direkt bei Pana ? Ich könnte ja mal in dem der S5 schauen... Grüsse Frank Hallo Frank, ich hatte das so verstanden, das durch die Splittung zwei Native Basis ISO zur Verfügung stehen. 100 Wie gewohnt, und dann den Startwert von High-ISO (640). Siehe meine obige Frage bzw. Aussage, das mir die 640 ein bisschen niedrig vorkommen. Mehr weiß ich allerdings auch nicht. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
frank.ho Geschrieben 7. April 2021 Share #14 Geschrieben 7. April 2021 (bearbeitet) vor 48 Minuten schrieb pero: Hallo Frank, ich hatte das so verstanden, das durch die Splittung zwei Native Basis ISO zur Verfügung stehen. Jupp - habe jetzt herausgefunden, dass die ISO-Auto bei LOW nicht über 800 hinausgeht, auch wenn es ein zu dunkles Bild gibt, und bei HIGH nicht unter 800 fällt, auch wenn das Bild zu hell wird.... Also eine ISO Begrenzung auf den gewählten Dual-ISO Bereich. Anregungungen für den praktischen Nutzen sind willkommen ... Grüsse Frank bearbeitet 7. April 2021 von frank.ho Link zum Beitrag Auf anderen Seiten teilen More sharing options...
hartin Geschrieben 7. April 2021 Share #15 Geschrieben 7. April 2021 vor 2 Stunden schrieb pero: Echt? Bei mir ging nix durcheinander. Ich musste hinterher nichts neu konfigurieren. Das ist aber mal seltsam. Mir ist nur beim rumspielen mit dem neuen jetzt explizit anwählbaren Dual-ISO Eintrag aufgefallen, das der der High ISO Bereich schon bei 640 losgeht. Das erscheint mir ein bisschen niedrig. Ich hätte irgendwas bei 1600 aufwärts erwartet. War bei mir auch schon beim letzten Update 1.7 so,einzig die Sprache(deutsch) und Datum/Uhrzeit(aktuelle)sind geblieben... habe wohl ein "Montagsmodell" der S1 erwischt? Link zum Beitrag Auf anderen Seiten teilen More sharing options...
pero Geschrieben 7. April 2021 Share #16 Geschrieben 7. April 2021 vor 2 Minuten schrieb hartin: War bei mir auch schon beim letzten Update 1.7 so,einzig die Sprache(deutsch) und Datum/Uhrzeit(aktuelle)sind geblieben... habe wohl ein "Montagsmodell" der S1 erwischt? Aua, da kannst du ja noch froh sein, das die Sprache nicht auf Chinesisch Kurzschrift mit Akzent gewechselt hat. 🙃 Tifoso hat darauf reagiert 1 Link zum Beitrag Auf anderen Seiten teilen More sharing options...
pero Geschrieben 7. April 2021 Share #17 Geschrieben 7. April 2021 vor 2 Stunden schrieb frank.ho: Jupp - habe jetzt herausgefunden, dass die ISO-Auto bei LOW nicht über 800 hinausgeht, auch wenn es ein zu dunkles Bild gibt, und bei HIGH nicht unter 800 fällt, auch wenn das Bild zu hell wird.... Also eine ISO Begrenzung auf den gewählten Dual-ISO Bereich. Anregungungen für den praktischen Nutzen sind willkommen ... Grüsse Frank Den praktischen Nutzen sehe ich darin, das man beim manuellen Umschalten bei 800 das gleiche Rauschverhalten hat wie bei 100. Falls ich die Sache mit der Basis ISO nicht komplett mißverstanden habe. Und entsprechend dann weiter bei 1600 etc. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
