ein neues Firmware Update steht zur Verfügung:
Firmware for FinePix X100 | Fujifilm Global
New function for the WIDE CONVERSION LENS WCL-X100 is added to the shooting menu. The function for the WCL-X100 can also be allocated to "Fn/RAW" button.
2.Hold the "AE/AF LOCK" when changing to OVF after one of 25 focus points(inner portion of 49 focus points) is selected in EVF or LCD.
<Notice> "AE/AF LOCK" will be canceled when changing to OVF after one of 25 focus points (outer portion of 49 focus points) is selected in EVF or LCD. In this case, you need to use EVF or LCD to hold the "AE/AF LOCK".
3.Change of "MIN. SHUTTER SPEED" setting in "ISO AUTO CONTROL" of the shooting menu will be reflected without OFF/ON operation.
