Guest User73706 Posted September 26, 2017 Share #1 Posted September 26, 2017 Werbung (verschwindet nach Registrierung) http://www.sonyalpharumors.com/novoflex-launches-new-reverse-adapter-sony-e-mount/ „For owners of Sony E-Mount lenses the NOVOFLEX RETRO-Adapters open up the world of extreme close-up photography with outstanding quality. The NOVOFLEX RETRO-Adapters lets you mount the lens in reverse position on the camera. The ring transfers all control functions. The NOVOFLEX RETRO-Adapters are supplied standard with a 58 mm filter diameter. Stepping rings are available for other filter sizes. Technical specifications: Size: 75 mm (2.95”) Weight: 160 g (0.35 lbs) Maximum extension: 550 mm (21.65”)“ Interessantes Gerät. Könnte für den ein oder anderen hier vielleicht interessant sein. Quote Link to post Share on other sites More sharing options...
123abc Posted September 26, 2017 Share #2 Posted September 26, 2017 Alternativ auch in deutscher Sprache Quote Link to post Share on other sites More sharing options...
Join the conversation
